Bamboo wings (with CF :)) and green epoxy. They will fit the bamboo board soon !
That’s how, thanks for sharing. Did you make that?
I know Starboard has one of the largest initiatives to push towards a more sustainable future. Click that link to check out my signature foil board hitting shops soon. It is thick and short and good for efoiling ![]()
We are doing various products using Bamboo and composites materials, board and foil are using also Green epoxy, foam rein fort from PET recycle bottle and cellulose fibers fabrics. I avoid also clear coating to add less chemicals on the board (and reduce cost and weight :)). A lot more to do i know !
Very nice and clever to set the fibers up along the wingspan.
Which airfoil section have you used ? What are the wingspan, max chord and max thickness ?
This was on of my first boards over two years ago fully eco built with entropy resin recycled eps core and bamboo but carbonized (it’s stronger)Uploading: 981CB807-A0DD-4AD4-9386-917701B5295A.jpeg…
