Gong Allvator Rise OR V2 X-Over Alu
I am about to start building an efoil. Thanks to this gorgeous forum I have been infected …
As a surfing newbie I ask myself if I should start with the “beginner foil” Gong Allvator Rise (that’s what Gong says on their website) or the Allvator V2 X-Over Alu (a more versatile foil according to Gong).
What’s your opinion and recommendation?
Christof
I think the 100 extra € would be well spent in the V2 X-over Alu.
Better control, stiffer setup with a tapered mast to fuselage connection.
@Manu, what’s your feeling ? Smoothness, take-off, top speed of V1 over V2 ?
Gong 2020-2021
Unfortunately, I haven’t finished my second inflatable project yet, so I haven’t been able to test the Gong V2 yet.
It is also my feeling to go with the V2. It is newer and has probably more flexibility in the future.
Thanks for the profile. This is really helpful as it shows the advantages of V2 against V1.
Best
Christof
The other parameter to look at is the wing section or volume. The Veloce is quite thin and tailored for speed but not so tolerant at slow speed for beginners. The Rise is the opposite: thick, a lot of volume and tailored for surfs at slow speed so tolerant but could become boring and saturate in speed (drag).
As the figures show, the wing series delivered with this X-Over Alu edition have a thickness and volume 20% lower than that of the Rise series. Something to know is that the Rise, formerly the “Classic” was launched in 2018 (Year one). The X-over wing is year 3 model which benefits from all the experience acquired on the wings developed since (Veloce, the xT (T for Tall) series, …)
2020 Rise (called “Classic” in 2018)
Model Wspan (cm) Proj Surf (cm2) Vol (l) Thicknss cm
M 70 1258 2 3
L 80 1643 3,12 3,5
XL 90 1844 3,6 3,5
2021 X-over V2
M 70 1250 1,59 2,4
L 80 1550 2,9 2,7
XL 90 1900 2,82 2,9
2020 Veloce
M 71 1000 0,6 1,3
L 82 1300 0,94 1,5
XL 94 1600 1,36 1,7
This is an AWESOME overview.
Puts facts to my feeling.
Many thanks
Best
Christof
I’d choose V2, but what size should I go? I am light weight (<70), but the foils are made for boards without all the weight of battery, motor, etc. I see that Takuma and Fliteboard have a 1800-1900 front wing and the Allvator X-over V2 in size L only has 1550 cm2.
Is that enough to get out of the water with a DIY-eFoil?
Is XL maybe too big / too slow / too boring as soon as I get “used to flying”?
Any thoughts?
At your weight I would take MT or L or LT depending on your skills. 1200 are definitely enough but dont take more than 1500.
If you can drive once I would go to the Veloce. But if you just want to buy a wing and spend more time practicing in the beginning, I would take the Fluid. But definitely with V2 mast.
Thank you - I was just about to decide to grab the Allvator Rise, which is not V2 as far as I can see, but a lot cheaper. They say all V2 front wings will fit, so why spend more than needed? :thinking:
I tried:
X-over XXL 2200cm2
Fluid XXLS 1750 cm2
Veloce L 1300 cm2
With 120KV motor and 5in prop and my 90+ kg i can drive with all but need to help Veloce jist a little with my arms to come out of the watter.
I see that Gong Kite / Wing / Surf options just mean different lengths of Mast.
And it seems that Allvator Rise Set can not change the front wing to X-over, because X-over is V2. So to upgrade you will have to buy whole new mast / fuselage / stab?! Not nice.
I find it all very confusing. Have sent them a message but don’t really expect a quick answer.
To sum your answers up:
  • choose V2
  • choose smaller, Veloce or Fluid (why?)
  • or choose V2 X-over size M :slight_smile:
for efficiency and speed the Fluid or Veloce. They are going towards high aspact.
For the beginning and slow driving up to 30 kph take the X-Over. With the Curve LT you do nothing wrong.
Take the the V2 Mast for stiffness
Gong generally costs only a fraction, but is not efficient.
What do you mean by this? Trying to learn. Thanks!
Hello! How does your building going ? i’m also think about GONG X-Over V2 - Alu 85
And don’t know how to calculate wing surface) i’m 100kg , do i need to buy biggest wing ? or XL with 1650cm2 will be good for me for beginning ?
Hi, I have been using the X-Over V2 Alu for the last year. I have the X-Over L and it’s plenty big for my 80kg I also have a Veloce XL 1600 the Veloce is thinner and faster even if it’s bigger. Those X-Over wings are good all around wings but they are pretty thick thus they have a lot of drag and give you a lot of lift but they are slower. I would not go bigger than XL even L would probably work.
Thank you so much for the very useful experience. How do you think, that Veloce XL will be good for beginners?
I have the old Veloce XL V1 the V2 and V3 are smaller but probably still big enough to learn on. You can go X-Over XL they are very inexpensive and later add a faster wing. I use the X-Over stab with the Veloce and it’s fine.
I have the three larger sizes of X-Over. Photo below for comparing.
I use the L most all of the time at 85kg weight as it feels the most comfortable for me but Iearned with the XL and then migrated to the smaller L as I gained skill and confidence.
I find that as I go to larger front wing the stability increases and the cruising speed decreases slightly.
