RamsUK
March 10, 2019, 4:33pm
1
Hi All,
Have recently purchased a Gong Allvator foil not fir my efoil but for surf foiling.
Thought I would share a few pics in case anyone was thinking od getting one and was interested in the build qaulity and set up. This is the 65cm mast and large foil. Build quality looks good and it’s very light, mast and foil seem fairly stiff and the prices are very reasonable
Hello ,
what is the size L or XL?
RamsUK
March 10, 2019, 4:44pm
3
Hi, that’s the Large wing with 65cm mast. When I ordered there was no extra charge for swapping the medium wing for the large
possibly can you give me the weight of the whole (mat + fuselage + wings)? thank you
RamsUK
March 10, 2019, 6:24pm
5
According to the gong website this foil and mast set up (L wing and 65cm mast) weight is 4,2kg
See all specs here
https://gongsupshop.com/epages/box1707.sf/fr_FR/?ObjectPath=/Shops/box1707/Products/GON8SFOILALLSURFCPTL
Riwi
March 10, 2019, 6:57pm
6
I think i got the medium wing. Here with a hiorth ”torpedo”
Riwi
March 10, 2019, 7:00pm
7
I would not call it light. Compared to my nobile it’s heavy. I like the bag!
Manu
March 10, 2019, 7:52pm
8
I bought the same one for my electric foil, I will keep you informed after the first tests…
In the meantime here is the link to my construction…
https://efoil.builders/t/hydro-v1-sss-56104-neugart-ple-40-12s-lipo-seaking-v3-130a/2136
Riwi
April 13, 2019, 4:51pm
9
Been riding twice and medium is perfect for beginners but to slow for me. I can start foiling at 20 amps easy.
Nice , so what will be your next wing ? Kind of feeling the same about my wing…
Hi, we have realy fast wing
Jezza
April 13, 2019, 8:22pm
12
Get the 65cm kite wing. It will fit on the fuselage and should handle a lot more speed.
Riwi
April 13, 2019, 8:31pm
13
Does it work with the back wing or should I change that one as well?
Jezza
April 14, 2019, 6:44am
14
I think the back wing you have should be fine.
Riwi
April 14, 2019, 8:50am
15
I sent an email to gong. Will post answer.
Jezza
April 14, 2019, 3:23pm
16
Do you have the mast profile for the gong mast by any chance? I need to cut the mast profile from my mast clamp.
Manu
April 14, 2019, 4:29pm
17
Riwi
April 15, 2019, 10:53am
18
Hi!
Regarding kite wing for surf foil. I got this answer from GONG:
“The Fuselage will need to be changed for the Kite wing to be used but yes the stabs for either kite or surf are interchangeable. You might want to think of switching ou the stab first, that should loosen it up a bit.”
Riwi
April 15, 2019, 2:47pm
19
The difference between kite and surf fuselage
Manu
April 15, 2019, 6:45pm
20
Other people who ride with Gong foil surfing have the same problem…?
