Those from forum are better than my design. I switched to those. I think you should be able to export from step files. I also added battery box project file there
Hi guys, congratulations on the forum, itβs gorgeous and full of info. I am writing from Italy and I ran to understand if you are printing these pieces with a normal 3d printer or used a resin 3d printer. Thanks so much for the information.
Normal, anycubic mega s in my case. Print hollow and fill with epoxy
Hello Guys, I would just Hole and two minors things of mast clam. Is there any chance to get original file or Exported in other format than stl / I m using FUSION just in case !
