I have a Gong M Allvator foil, and Flipsky 65161 motor. Anyone have a mast clamp file to print.
Hey Sami, when you export your 3d files to stl to 3d print them, make sure you check the high resolution in the option tab. Your pieces will be much much smoother.
I had the same problem on my SLA 3D printer.
You are right. And these parts were out of SLA printer with 0.100mm layer height without any post processing except washing them
Yes, Great, That is the same mast as the gong. The model looks very nice. May I have those files please.
Wow could I have that duct file please. I appreciate your design.
I am going to share all the cads in a build thread this weekend
Thank you, Look forward to it. It looks like you ran all 3 of your phase wires down the same passage in the mast. Did you go with a round hole in the side of the mast or a slot. Also make sure you smooth all the edges of the mast hole because those silicone phase wires get razor like cuts in them very easily.
I am running late to wrap up the build thread, sharing the cads here for you guys:
https://drive.google.com/drive/folders/1ZUnQpcG3fu-KpdWrBoMgi-C_wIW39S4l?usp=sharing
Thanks I love your design
have you tested that prop?
which prop is on there?
Thats PM prop but Flying Rodeo prop also fots in this duct
is there a 3d file for this duct to share ?
duck and prop are from pacificminster build. I never tested the prop or duct and moved to Flying Rodeo prop with another ducks someone shared here
Could you share? I designed a clamp for F5085 a while back, but if you have something ready to go, I might take a shortcut!
I have also Mastclamps for the Ging Mast and the Flipsky Motor
hello sami, any chance you have the mast clamp file without the mast profile cut out? I have a different mast and trying to fit this clamp to it. I very much appreciate it. cheers
These are great, thanks @samisin
I see two different mast clamp files in here. One in the “gathered parts” folder and one in the “flipsky motor mount” folder. Are they both meant for the gong/chinese mast and flipsky motor? Also, did you ever export the STL files in high resolution?
