Hi all, looking for experienced opinions on a ~50L 4’6” wing board vacuum build I’m trying to keep super light. I don’t want a box failure but I’d be fine with a board that dings easily if I drop it on a rock, though not from pressure dings from just standing on it.
Option 1 : Pretty light (too light??)
2oz s glass entire top
4oz carbon/innegra whole top and rails
1/8” 5lb divinicell standing area
2oz s glass standing area
1lb EPS CORE
3 x 4oz carbon innegra overlapping patches for foil box.
4oz carbon/innegra entire bottom and rails
2oz s glass entire bottom
Option 2: heaviest
Same as 1 but 1.5lb and no divinycell, just some patches over foot locations
Option 3: heavier
Same as 1 but divinycell entire top (and bottom?)
Option 4: lightest
Same as 1 but no 2oz S glass finish, just 4oz carbon innegra.
Other stuff:
- 1.5” thick HD foam track foil box
- Tuttle box through track box going to upper skin
- HD blocks under footstraps and leash plug.
I’d like to finish as light as possible. All the fast guys in SF with custom boards have a peel ply finish with no pad. I’m not sure how they seal from pinholes. I think if I glass the 2oz separately that should fill the pinholes from the lower layer, correct? Or do I need a micro bead/epoxy rub ove that as well? If I just finish with carbon/innegra (which can’t be sanded) can I just do a microballoon /epoxy rub on that to finish?
Anyone make a board so light you got pressure dings? Anyone make a 1lb eps board and do a 4+2 oz like #1? Any issues?
