Great deal on battery pack
Maybe too good to be true!
I found this over at Endless Sphere about it: EV West Too Good to be True? 50¢ per cell, new | Endless Sphere DIY EV Forum
Seems about the same type of deal as the 48v 6.4ah 307.84wh Lithium Ion 13s4p 52x 18650 Cells – Battery Hookup – bad energy density (though the EV West ones are a bit better), but high discharge and very cheap. Seems very usable for low budget eFoil with low runtime!
Volvo XC90 60V 32Ah Lithium Battery Module has also been looking good to me, although the weight is quite significant.
Thanks for posting about this battery–I had not seen it before.
Update: Found this video and pcb for adding a plug-and-play BMS:
Thank you. I placed an order for a couple.
How are you planning to utilize them? Price is tempting, but I think I would need 4 for the capacity I want.
It should be enough to test my build. I may need something else in the future.
By the way, I think I got them.
Did you buy the BMS pcb from PCBway?
Not Yet. A friend of mine is going to tell me what to get. It is my first DIY build.
I ordered two more. Having a charger, a BMS with 14-pin contacts, and my own 3D-printed battery box makes sense to scale it up a bit. It is not ideal, but I can focus on other things for right now.
I don’t think there is any need for this.
