Hey guys I’m making a remote with a Hall effect sensor but I can’t find anywhere how to wire it in place of the potentiometer. Thanks in advance.
You can find loads of diagrams and tutorials on the internet, but best is to look into the datasheet of your specific sensor.
Most of the time - if you look at the side with the rounded edges - you have VCC on the left pin, then GND in the middle and the signal pin on the right.
Also find out the required supply voltage.
