Up for sale is my hand-built wooden E-Foil, a one-of-a-kind setup made with premium components and careful craftsmanship.
Built as a personal project — selling due to lack of time. Perfect for riders who want a ready-to-ride custom E-Foil.
Technical Specs
- Board: Hand-crafted from Paulownia wood – lightweight and unique.
Dimensions: 145 × 67 × 12.8 cm (≈ 86 L volume, ~11 kg)
- Motor: Robust FR motor (similar to motors used in Lift Foils) — reliable and powerful.
- ESC: Trampa 75/300, water-cooled using the MantaFoils cooling system. Mast length: 75 cm.
- Remotes: Flipsky remote + original MantaFoils remote (backup included).
- Battery: Original MantaFoils 50 Ah pack — high range. Charger included.
- Front Wing: Manta F1200 Carbon Wing — smooth carving & cruising, suitable up to ≈ 80 kg rider weight.
Optional Wings (sold separately)
- Manta F1600 Carbon Wing (Freeride, 1600 cm²) — stable and efficient at medium speeds, ideal for long rides.
- Manta F1350 High Aspect Carbon Wing (with cover) — optimized for higher top speed and better glide; less lift, great for gliding performance.
Location & Shipping
Located in Freiburg, Germany — I am also often in Genoa, Italy.
Pickup preferred. I can assist in arranging best-possible shipping if needed (shipping costs and logistics to be agreed).
Price
3600 EUR — open to fair offers
Serious inquiries only — happy to provide detailed photos and answer technical questions.
Original MantaFoils E-Foil Motor Unit with 75 cm Mast – Perfect for DIY Builds
For sale is an original MantaFoils E-Foil motor unit with a 75 cm mast —
a robust and reliable setup, identical to the motor system used in MantaFoils production E-Foils.
Condition:
Motor and mast are fully functional. The installed ESC (Trampa 75/300 with water cooling) is defective and needs replacement or repair.
Ideal for anyone who wants to build or upgrade their own E-Foil project.
Details
- Original MantaFoils motor unit – powerful and proven performance
- Mast length: 75 cm
- ESC: Trampa 75/300 (included but not working)
- Motor + mast tested and fully operational
Optional / Additional DIY Parts Available
I also have several other components that can complement this setup or be used for your own custom build:
- Various Remotes + Receivers (Flipsky, Maytech, MantaFoils)
- SurLock battery cables
- Assorted screws and hardware
- new original Battery MantaFoils 50 Ah and Fuselage with Foil
- Optionaol adapter for outboard use
No board included – perfect for DIY builders or as a spare parts donor.
Price
950 EUR – open to fair offers.
Would love to see this setup continue as part of someone’s next great DIY E-Foil project!
MantaFoils F1350 High Aspect Carbon Wing – Like New, with Protective Cover
For sale is a near-new MantaFoils F1350 High Aspect Carbon Wing including its protective cover.
- Surface: 1350 cm²
- High Aspect Design – optimized for higher top speed and extended range
- Ideal for efficient cruising and long glide sessions
- Less lift – not suited for tight carving or sharp turns
- Perfect for sporty riders who value speed and efficiency
Note: I also have the matching fuselage with screws available.
Price
495 EUR
For sale is a MantaFoils F1600 Carbon Wing – the trusted standard for most riders.
- Surface: 1600 cm²
- Very stable and efficient at low to medium speeds
- Perfect for long, smooth flights with excellent range
- Allows easy, flowing turns – ideal for comfortable cruising
The perfect all-round wing for both beginners and advanced riders.
Price
390 EUR – fair offers considered.
For sale is a brand-new Volt 3 E-Foil battery with 50 Ah capacity – Long Range version.
Perfect for DIY builders or as a high-performance replacement battery.
Technical Specifications
- Configuration: 14S12P
- Nominal Voltage: 50.4 V
- Capacity: 50 Ah
- Continuous Discharge Current: 90 A
- Peak Current: 120 A
- Protection Rating: IP67 (fully waterproof)
- BMS: Smart Battery Management System with short-circuit, over/undervoltage, and over-temperature protection
Special Features
- Magnetic power switch – spark-free connection
- Double-sealed housing for maximum water protection
- Bluetooth app for real-time monitoring (voltage, current, temperature, and status)
- Ride time: up to ≈140 minutes (depending on rider weight, wing, and riding style)
Brand new – purchased in July directly from MantaFoils.
Original invoice available as proof of purchase.
Price
1.300 EUR
