Has anyone used this as part of a kill switch?
Hi All,
Can I have some advice please, will this device handle switching off under full load ?
I expect I will fall off many times when I start.
The ESC I purchased last night shuts down after 3 second of signal loss. I think 3 second I a long time so looking for a quicker method.
Thanks in advance.
Alex
https://www.ebay.com.au/itm/300A-Power-Switch-On-Off-16S-Flier-for-High-Voltage-and-Amps-ESC-Controller/263111954651?var=562110683205
Hello
I have the same that works very well, except that my switch works upside down, it is necessary to put the switch to 1 (closed) to stop the engine!
Hi philippe Thank-you how high a load are you switching off? have you posted a link of your set up? Can you send a link if you have, if not could you please do so. when you say “switch to 1” is that adding power via a secondary micro controller to switch the main load off or is it a state that is explained with the manual of the device as yet I have not found any info on the device so a bit confused.
Thanks.
I put two 16A Lipo batteries in 12S series, in fact I go to 1 to power through a secondary microcontroller to turn off the main charge, I have to use the next device with a switch ! here are the links
https://www.ruedelamer.com/accessoires-moteurs-coupe-circuits-de-securite-64151.html
https://www.flashrc.com/images/file/Notices/emcotec/SPS_EN.pdf
