Hello, I’m new here and to e-foiling and I’m building my first board now copying Fillemupps rifle case build
I’m using flipsky 65161 120kv motor and flipsky 75200 esc
I already once had everything working and tested it but there were problems with waterprooffing and power
I used diffirent battery for that run but I now have bigger battery for it than my old battery pack that was 36v and now my new one is 60v so it should help with power
The problems is that after my last run everything worked but after I changed my battery it won’t work
I tried to change settings in vesc to match my new battery and to double check everything but when I’m in the focc settings trying to measure my motor it says: “Could not measure the motor resistance and inductance.” it makes some noises when trying to measure it but after it always says that same thing
Now because before it worked and I successfully did these settings and now it won’t work I think I may have damaged my vesc in someway.
Sounds more like a connection problem than a vesc problem to me but there are some users that got issues when changing voltage. Seems motor detection can be affected by it and the 75200 VESC reportedly also has noisy measurements for the motor control (which would be bad for this)
Some basic things to try:
Connect the old battery. Does it work again?
try to set parameters via the connection wizard instead of the way Ludwig does it in the video.
Disconnect motor from esc. Check motor turning, is it bogged down, increasing torque with rpm when turned by hand, ? (=Motor is shorted)
Connect motor to esc, turn again by hand. Increasing resistance when turned? (=esc is shorted)
Check all motor connections. Any possibility of poor contact?
check motor wires at enter and exit through motor endcap, mast, box etc. Any signs of damage?
Sorry for delay, last year winter came and other projects took over, and this year I resumed this only like month ago
I don’t exactly know what was wrong with my settings but I started programming my vesc from scratch by following Ludwigs video again and everything worked with zero problems first try. Maybe taking a break helped to clear my mind enough to concentrate
This time I had no problems with waterproofing but still lacked power somehow. I think my hardware should be enough to get me up on foil but last weekend I tried and there was still just not enough power, maybe because of vesc settings?
My battery is E-go scooter battery 26Ah 60V, wing is gong allvator X-Over, motor is flipsky 65161 120kv and esc is flipsky 75200 all in Nuprol XL rifle case. For now I have prop guard but I allready tought about removing it for more power
I weigh somewhere around 85-90kg so do you think it would be possible to work as is?
I think I need to buy wetsuit so I could test this couple of times before winter hits again. Water was around 14c° last weekend so water is already starting to get a bit cold for my taste
85-90kg rider my weapon case needs 220A motor current on a 3-blade 6" prop, 65161 motor
Translate to roughly 6kW / 100-150A battery current
Make sure your battery can handle this!
Also I would indeed remove the guard to lower the drag in the water…
Do you have experience on other eFoil or is it you first ride?
Yes, this is my first time building and (trying to) ride one ever. That is why I pretty much want to copy somebody that have done this before, in this case Fillemupp
I have 3-blade 5" prop
Battery is made of EVE ICR18650-26V cells in 16S10P pack, no bms
