Hi guys im about to pull the trigger on a flipsky motor for my build / modification,as a heavier rider at 105kgs,would you recommend the flipsky 65161 or or the larger 70165.
Many thanks in advance.
I would think either would work. Lots of builds here that use 65161.
Make sure you choose round shaft with thread type to optimize your prop choices.
I know that you are attempting to return your Hisun rig to a functional state but it might be better if you put all of your questions into one topic rather than shotgun it. ![]()
You might also consider just biting the bullet and buy a good Gong mast/foil setup and a Flipsky kit (motor,VESC,remote) and get it going.
