Help bidirectionnal command with 75100 v2 pro
Hello. I have a problem with my new Flipsky 75100 VESC. When I activate my VX3 remote control the first time, the current signal sent is positive; if I release it slightly, the motor stops, and if I press the trigger a second time, the current signal sent is negative and my motor reverses its rotation.
I am in UART mode , It seems that everything is correctly configured in Vesc tool. All parameters concerning reverse rotations and brakes are, a priori, correctly entered.
I must have forgotten something, does anyone have any idea? Thanks.
Could you post screenshots of your settings?
Are you using “Current Control No Reverse”?
Yes I did , current no reverse;
I have tried to launch a new motor détection and now I have a fault code about overcurrent , the detection failed;
It seems as a bad welding ; I am going to redo them ….
