Hi everyone,
I’m building my first eFoil and have already managed to test it a few times using four 6S 4500mAh LiPo batteries in a 12S configuration. However, with this setup, I only get around 20 minutes of ride time. To increase the range, I’m planning to build two 6S4P batteries using 21700 Molicel P45A cells.
I’m planning to run the packs without a BMS, as my external charger handles cell balancing during charging. The charger only supports 6S, which is why I need the batteries to be 6S.
The main challenge I’m facing is the limited internal height of the board. If I can arrange the cells 8 side-by-side and 3 high (total of 24 cells) (horizontal orientation), the packs would fit inside. This Printables.com model 6S4P honeycomb 21700 3 row design 22.2V battery by DIY500AMP.COM | Download free STL model | Printables.com) for cell arrangement would work well for my board.
Since I’m a beginner in battery building, I want to make sure I get everything right the first time. Could someone help me figure out the best way to configure the nickel strips for this setup? I’d really appreciate any advice on proper current handling, layout, and overall build quality.
Here’s a picture of the layout:
Thanks in advance!
