Hello. I am new here. I want to build an e-foil. My expertise is in the board design and not the motor assembly/electronics. I would be willing to hire someone to build out the motor, battery and controller part. I want to use a very strong motor as I am a heavier guy (210lbs). Any advice?
where are you located?
