Help with VESC Tool Config
Dear folks,
Since my last post here I think I progressed a lot. Especially considering my quite limited knowledge of electronics.
Thanks for all the people who contributed to make this forum so informative.
Now I would like some help if I may to fine tuning the VESC. There are too many parameters and I’m not quite sure about the ones who really matter.
My setup is a 12s2p 9A (2 x 6s2p drone batteries), 75100 Pro VESC, 6384 140Kv Flipsky Motor and Maytech remote.
Below my configurations for Motor and App. I appreciate with someone can help to optimize the inputs. It seems I’m getting maximum throttle at 25%. No sure why.
My plan is to give back to the community a template that can be copied.
Many thanks in advance,
OC
MOTOR
  1. General Tab
    General
    Motor Type: FOC
    Invert Motor Direction: False
    Sensors
    Sensor Port Mode: PWM
    ABI Encoder counts: 8192
    Sine Amplitude: 1.000 V
    Cosine Amplitude: 1.000 V
    Sine Offset: 1.650 V
    Cosine Offset: 1.650 V
    Sin/Cos Filter Constant: 0.5
    Sin/Cos Phase Correction: 0.00°
    Current
    Motor Current Max: 60.00 A
    Motor Current Max Brake: -30.00 A
    Absolute Maximum Current: 150.00 A
    Slow ABS Current Limit: False
    Max Current Scale: 100%
    Min Current Scale: 100%
    Battery Current Max: 8.00 A
    Battery Current Max Regen: -3.00 A
    Input Current Limit Map Start: 100%
    Input Current Map Filter: 0.005
    DRV8301 OC Mode: Current Limit
    DRV8301 OC Adjustment: 16
    Voltage
    Battery Voltage Cutoff Start: 42.0 V
    Battery Voltage Cutoff End: 38.0 V
    Battery Voltage Regen Cutoff Start: 50.0 V
    Battery Voltage Regen Cutoff End: 51.5 V
    Battery Filter Constant: 45
    RPM
    Max ERPM: 90000.00
    Max ERPM Reverse: -100000.00
    ERPM Limit Start: 80% (0.80)
    Wattage
    Maximum Wattage: 1500000.0 W
    Maximum Braking Wattage: -1500000.0 W
    Temperature
    Motor Temperature Sensor Type: Disabled
    Beta Value for Motor Thermistor: 3380.0 K
    Coefficient for PTC Motor Thermistor: 0.610 %/K
    Custom NTC/PTC Resistance: 10.00 kΩ
    Custom NTC/PTC Base Temperature: 25.00 °C
    Acceleration Temperature Decrease: 15%
    MOSFET Temp Cutoff Start: 85 °C
    MOSFET Temp Cutoff End: 100 °C
    Motor Temp Cutoff Start: 85 °C
    Motor Temp Cutoff End: 100 °C
    BMS
    BMS Type: None
    BMS Limit Mode: Overtemp & SOC (Checked)
    Temperature Limit Start: 45 °C
    Temperature Limit End: 65 °C
    SOC Limit Start: 5% (0.05)
    SOC Limit End: 0%
    VCell Min Limit Start: 2.90 V
    VCell Min Limit End: 2.50 V
    VCell Max Limit Start: 4.20 V
    VCell Max Limit End: 4.30 V
    Forward CAN to Local: Disabled
    Advanced
    Minimum Input Voltage: 36.0 V
    Maximum Input Voltage: 60.0 V
    Minimum Duty Cycle: 0.50%
    Maximum Duty Cycle: 95.00%
    Minimum Current: 0.05 A
    Fault Stop Time: 500 ms
    Auxiliary Output Mode: Off
    Duty Cycle Current Limit Start: 100% (1.00)
  2. FOC Tab
    General
    Sensor Mode: Sensorless
    Motor Resistance (R): 32.2 mΩ
    Motor Inductance (L): 23.87 μH
    Motor Inductance Difference (Lq - Ld): 7.66 μH
    Motor Flux Linkage (λ): 5.566 mWb
    Current KP: 0.047
    Current KI: 64.46
    Observer Gain (x1M): 32.38
    Sensorless
    Openloop ERPM: 1500
    Openloop ERPM at Min Current: 0%
    Openloop Hysteresis: 0.10 S
    Openloop Lock Time: 0.00 S
    Openloop Ramp Time: 0.10 S
    Openloop Time: 0.05 S
    Openloop Current Boost: 0.00 A
    Openloop Current Max: -1.00 A
    Start Current Decrease: 100% (1.00)
    Start Current Decrease ERPM: 2500
    Saturation Compensation Mode: Disabled
    Saturation Compensation Factor: 0%
    Temp Comp: False
    Temp Comp Base Temp: 25.0 °C
    Hall Sensors
    Sensored ERPM Start: 2500
    Sensorless ERPM: 3500
    Hall Interpolation ERPM: 500
    Hall Table (0 to 7): 255 (All indexes)
    Hall Sensor Extra Samples: 3
    Encoder
    Encoder Offset: 180
    Encoder Ratio: 7
    Encoder Inverted: False
    HFI
    HFI Ambiguity Resolve Mode: Six Vectors
    HFI Ambiguity Resolve Current: 60.0 A
    HFI Ambiguity Resolve Threshold: 15%
    HFI Samples: 16
    HFI Start Voltage: 20.0 V
    HFI Run Voltage: 4.0 V
    HFI Max Voltage: 6.0 V
    HFI Gain: 0.3
    HFI Max Error: 0.3
    HFI Current Hysteresis: 0.00 A
    Sensorless ERPM HFI: 3000
    HFI Start Samples: 5
    HFI Observer Override Time: 1.0 ms
    VSS
    HFI Samples: 16
    Openloop ERPM: 1500
    Filters
    Enable Phase Filters: False
    Maximum ERPM for phase filters: 4000 ERPM
    Disable Phase Filter Fault Code: True
    Offsets
    Offset Calibration Mode: Calibrate on Boot (Checked)
    Auto Calibrate / Write Enabled: False / Unchecked
    Current Offset 0: 2042.48
    Current Offset 1: 2041.92
    Current Offset 2: 2046.53
    Voltage Offset 0: 0.0018 V
    Voltage Offset 1: 0.0002 V
    Voltage Offset 2: -0.0020 V
    Voltage Offset Undriven (0 to 2): 0.0000 V
    Field Weakening
    Field Weakening Current Max: 0.00 A
    Field Weakening Duty Start: 90.00%
    Field Weakening Ramp Time: 200 ms
    Q Axis Current Factor: 2.00%
    Advanced
    Zero Vector Frequency: 30.0 kHz
    Dead Time Compensation: 0.120 μs
    Speed Tracker Kp / Ki: 2000.00 / 30000.00
    Duty Downramp Kp / Ki: 50.00 / 1000.00
    Control / Current Sample Mode: V0 Only / Longest Zero Time
    Observer Gain At Minimum Duty: 5% (0.05)
    Current Filter Constant: 0.1
    Current Controller Decoupling: FOC_CC_DECOUPLING_DISABLED
    Observer Type: FOC_OBSERVER_MXLEMMING_LAMBDA_COMP
    D Axis Gain Scaling (Start / Max Mod): 90% / 90%
    MTPA Algorithm Mode: Disabled
    Observer Offset: -1.00
    Speed Tracker Position Source: Corrected Position
    Short Low-Side FETs on Zero Duty: False
    Overmodulation Factor: 1
  3. PID Controllers Tab
    Common & Speed Controller
    PID Loop Rate: 1000 Hz
    Speed PID Kp / Ki / Kd: 0.00400 / 0.00400 / 0.000400
    Speed PID Kd Filter: 0.2
    Minimum ERPM: 900
    Allow Braking: True
    Ramp eRPMs per second: 25000
    Speed Source: PLL
    Position Controller
    Position PID Kp / Ki / Kd: 0.02500 / 0.00000 / 0.00000
    Position PID Kd Process / Filter: 0.00035 / 0.200
    Position Angle Division: 1
    Gain Decrease Angle: 0.0°
    Position PID Offset Angle: 0.0000°
  4. Additional Info Tab
    Setup
    Motor Poles: 14
    Gear Ratio: 3
    Wheel Diameter: 83.00 mm
    Battery Type: BATTERY_TYPE_LIION_3_0_4_2
    Battery Cells Series: 12
    Battery Capacity: 9.000 Ah
    Motor No Load Current: 1.0000 A
    Motor General
    Motor Brand / Model: (Blank)
    Motor Weight: 0.00 g
    Position Sensor: No sensor
    Description & Quality
    Text: “A motor description can be edited here.”
    Metrics: Bearing Quality (0), Magnet Quality (0), Construction Quality (0)
  5. Experiments Tab
    Setup Parameters
    Duty Sweep: From 0.00 to 0.50 | Step: 0.02 | TS: 2.00 s
    Current Sweep: From 0.00 to 20.00 | Step: 2.00 | TS: 2.00 s
    ERPM Sweep: From 0 to 10000 | Step: 500 | TS: 2.00 s | End: 10000
    EXT Monitor
    Victron Energy: COM7 (Disconnect status)
APP
  1. General Tab
    General
    APP to Use: PPM
    VESC ID: 114
    Timeout: 1000 ms
    Timeout Brake Current: 0.00 A
    CAN Baud Rate: CAN_BAUD_500K
    Pairing Done: False
    Enable Permanent UART: True
    Shutdown Mode: OFF_AFTER_30M
    CAN Mode: VESC
    UAVCAN ESC Index: 0
    UAVCAN Raw Throttle Mode: Current Control
    UAVCAN Status Current Mode: Motor Current
    UAVCAN Raw RPM Max: 50000
    Enable Servo Output: False
    Kill Switch Mode: Disabled
    CAN Messages Rate 1
    Can Status Rate 1: 50 Hz
    Can Messages Rate 1: Status 1, Status 2, Status 3, Status 4, Status 5, Status 6 (Checked)
    CAN Messages Rate 2
    Can Status Rate 2: 5 Hz
    Can Messages Rate 2: Status 1, Status 2, Status 3, Status 4, Status 5, Status 6
    Tools
    Servo Output: Center
  2. PPM Tab
    General
    Control Type: Current No Reverse
    Median Filter: True
    Safe Start: Regular
    PID Max ERPM: 150000.00
    Positive Ramping: 0.40 s
    Negative Ramping: 0.20 s
    Max ERPM for direction switch: 4000
    Smart Reverse Max Duty Cycle: 7% (0.070)
    Smart Reverse Ramp Time: 3.00 s
    Multiple VESCs over CAN
    Multiple VESCs Over CAN: True
    Traction Control: False
    TC Max ERPM Difference: 3000
    Mapping
    Pulselength Start: 1.0000 ms
    Pulselength End: 2.0000 ms
    Pulselength Center: 1.5000 ms
    Input Deadband: 15%
    Throttle Curve
    Throttle Expo: 0%
    Throttle Expo Brake: 0%
    Throttle Expo Mode: Polynomial
  3. Nrf Tab
    Radio
    TX Power: 0 dBm
    Speed: 1 MBit/s
    Radio Channel: 76
    Integrity
    CRC: 1 Byte
    Send ACK: True
    Retry Delay: 250 µS
    Retries: 3
    Address
    Address 0: 198
    Address 1: 199
    Address 2: 0
  4. IMU Tab
    General
    IMU Type: IMU_TYPE_INTERNAL
    Use magnetometer: True
    Sample Rate: 200 Hz
    Accel/Gyro Filter: IMU_FILTER_MEDIUM
    Accel lowpass filter X: 0.0 Hz
    Accel lowpass filter Y: 0.0 Hz 0.0 Hz
    Accel lowpass filter Z: 0.0 Hz
    Gyro lowpass filter: 0.0 Hz
    AHRS
    IMU AHRS Mode: AHRS_MODE_MADGWICK
    Accelerometer Confidence Decay: 1
    Mahony KP: 0.3
    Mahony KI: 0
    Madgwick Beta: 0.1
    Rotation
    Imu Rotation Roll: 0.000°
On land/desk?
If yes, thats expected.
No resistance + current control → full RPM at almost no throttle.
Thanks. I forgot to mention it’s during a bench test.
Bench = zero resistance.
Current control scales current from 0 to max over throttle range.
So for you 10% throttle = 6A.
Easily enough to get the motor to max RPM with no load.
If you want RPM to follow throttle with no load, use duty cycle control mode.
Which parameter is that? And does it changes anything on water?
And no, either works on water.
I personally use current control.
Thanks @Jan12 . Is there anything else you would change?
Max amps = 60 seems pretty low. If you are super light and your board is efficient, maybe it will be fine, but I have my 75200 vesc set to 140 amps with absolute at 225. If you have your vesc cooled with a heat sink, you can beef up those amps a bit. I’ve only had 75200, so I’ll let others comment how high you can go.
A friend from the forum sent me his VESC files and it’s working like a charm now. It has 80 A as Motor Current Max now.
My VESC is the 75100 not the 75200 :slight_smile:
