HGLTECH HI200 75V High Current 200A ESC Base On Vesc With Water Cooling Enclosure For E-FoilSpec:
Voltage:14-75V( safe for 3-16S)
Continuous Current : 200A
Max Current :300A
Supported sensors: ABI, HALL, AS5047,AS5048A
EPRM:150000
Feature:
Regenerative braking
Sensored or sensorless operation + hybrid mode
Configurable RPM-, current-, voltage- and power limits
Input source: PPM, Analog, NRF Nyko Kama Nunchuck
Communication ports: USB, CAN, UART
Throttle curve and ramping for all input sources
Seamless 4-quadrant operation
Motor revolution, amp hour, watt hour counting
Real time data analysis and read out via communication ports
Adjustable protection against:
Low input voltage
High input voltage
High motor current
High input current
High regenerative braking current (separate limits for the motor and the input)
High RPM (separate limits for each direction)
Digital VCC and analog VCC are produced by different voltage regulators respectively to make the system AD conversion more accurate
Motor wire: 8AWG
Power cable: 10AWG
Get yours here:https://www.gd-hgl.com/products/hgltech-hi200-75v-high-current-200a-esc-base-on-vesc-with-water-cooling-enclosure-for-e-foil
                Vitalii
                    September 18, 2020, 11:15am
                  2
It’s “sold out” and even not mentioned the price
                Jezza
                    September 18, 2020, 11:16am
                  3
              You probably shouldn’t have brought the connectors out the top. How will anyone close their hatches now?
                SoEFoil
                    September 18, 2020, 11:31am
                  5
              The ESC can be rotated by 90 degrees. That side is only 52mm high under a 80+mm high hatch. A 30mm radius is OK to me. The wires can be horizontal if the water in-outlets are pointing upwards.
                theone
                    September 18, 2020, 12:49pm
                  6
              One advantage could be the power cables are not competing for space with the cooling tubes ?
              Come down below the 300 mark and bring the powercBles out on the horizontal and you’ll be onto a big winner!
              it seems so,yet it needs to be proven.
              could you pls expain your suggestion a bit,thanks
                jkoljo
                    September 24, 2020,  9:17am
                  10
              The point is to make it a bit cheaper than 300 USD and make the cables run horizontally.
                theone
                    September 24, 2020,  9:46am
                  11
              The last time a committee designed a race horse a camel was born.
              We can make it $319 and one extra vx2 remote to be shipped if you order via this link,HGLTECH 200A
              Have anyone tried vx2 remote for efoil?
How can you say it is for efoil when it is not waterprotected at all and add it to a vesc specially made for efoil/water?
Probably better and More fait to lower the price 30-40 dollar instead.
              we just add the remote for extra free gift,you can use it for esk8.About the discount,we are having flash sale promotion ,pls stay tuned on https://www.gd-hgl.com/
                Toto44
                    September 25, 2020,  7:59am
                  15
              HGLTECH 2.4Ghz PPM YK01 remote control
Does this one have a “joystick” with poti or hall sensor on the stick?
              yes,its joystick is with piti
                SoEFoil
                    September 26, 2020,  1:33pm
                  19
              Would you have some pictures of this test session ?
                brycej
                    September 26, 2020,  3:02pm
                  20
              Why is their customer service better than any other company did you have an issue?
Or did you work in their customer service?
                Vicdes2
                    September 26, 2020,  3:03pm
                  21
              Looks like HGLTech might be taking their promotion on this forum a bit too far! That person joined 5 hours ago and has 3min of read time…
              If HGL-TECH is advertising with multiple accounts and trying to give out fake reviwes, i wouldnt be very surprised
