Would you indicate the dimensions of this HI100 square version ?
Will there be a sqare layout version for your HI200 as well ?
Do you have an ongoing project for a more waterproof casing for your HI100 / HI200 75300 ESCs like a potted version ?
You do not have any 200a version with built in bluetooth like The vesc 75/300 so it is possible to use the uart for The maytech remote and still log data and configure through mobile Phone
Hmmm… I am not following you totaly now.
Do you reffering to The PPM signal for throttle?
I meant The cable you connect to The uart to get rpm/ volt etc on The remote.
If I would like to connect to get that information i assume i would need a splitter to have Both bluetooth module and get that information to my maytech 2005 remote?
To be honest it’s not really worth sending RPM data etc to the remote. So I wouldn’t bother with that.
You don’t need the uart connected for the voltage so that will still work.
