My beloved hisun efoil has broken? I layed it up for the winter, now the controller doesn’t work! Probably water ingress causing corrosion over winter
Motor and batteries test like new but i need to replace esc with flipsky 75200 , i will not use flipsky 75100 as i have burn out three 75100s on other projects and they are no good for efoils
my question is? if I put the flipsky vesc and pwm (remote throttle reciever/transmitter ariel) all in a plastic waterproof box then placed into board? will i still get signal to remote
it is much easier to build and easier to waterproof if all electrics is in one box?
Yer, your right i have disassembled and tested, the only fault was cable’s were high resistance? This is due to water impedance
But unfortunately have already ordered new esc and associated hardware so will upgrade to vesc plus new uupgraded remote, thankyou for response, robin from UK
