I got myself a board that i understand is a Hisun board (sold as a norwegian brand under Control Powerfly name here in Norway).
This hisun board is the only foil/efoil board i have ever ridden.
Now i am playing with the idea of building my own board from scratch as many of you here are doing.
But is it worth it? I mean yes, its fun to do the build etc. But what will be better on a self built board vs Hisun board i already have? Can i make it lighter? Can i make it easyer to fly for beginners? can i make it go longer?
Or should i just modify the hisun board? In this case i am thinking of doing the board itself shorter, remove the prop guard, change propeller, and maybe change the foil wings? When going faster tha 80-85% i have to push the nose downwards due to the angle of the front wing. it looks weird and feals weird.
Any recomendations for complete DIY kits?
Feedbacks will be much apreciated as i try to learn and understand this sport/hobby.
Although I’ve never ridden a Hisun, I think there is potential for improvement. It is probably a good board for a beginner, but as you increase your skills, a more advanced board might open up new possibilities.
Improvements could be:
Shorter, lighter board
Thinner motor
Longer mast
More advanced, changeable hydrofoil wings
Faster max speed
Longer range/lower consumption
Maybe you can test/rent one of the newer commercial boards to experience the difference.
In the end it is a question of personal preference.
I had my hisun version 2 for a year now and have found it faultless
You need it fill the motor with mineral oil, grease the inside of the controller and drill drain holes, grease and tape all wire connections, wipe and dry everything after use,
A bit of water ingress into battery box does not effect anything and i have not been elecuted yet?
The motor controller is based on vesc so can be a little fickle (this is the nature of vesc) , but always works after resetting
I have around 500 hours usage and find the batterys still last one and a half hours, no problems to report
