Hello! I’ve built my own Axis based E-foil based around the 19mm ALU mast and Red fuselage.
My goal is very low wattage e-foil cruising with large foils. So far I’m at ~430W on an Axis 1310. But I want to go even bigger…
Does anyone know of small volume builders who are making large custom foils for Axis?
My options right now look like:
- Sabfoil Leviathan 1750 foil/fuse/stab and adapter doodad to Axis 19mm mast.
- Gong Sirius XXXL, foil/fuse/stab and adapter doodad to Axis 19mm mast.
- Build a foil myself. Use an old fuselage as a plug… how hard can it be?
-Adralien (LuxMonday on YouTube)
