Hello,
I have got a new motor and a new maytech esc. The Cables from the motor have got three colors (blue, red and yellow). But the three cables from the ESC are all black.
I don´t know, how to put the right connection.
Thank you for help.
Hello,
Thank you for help.
Just connect them, the only thing that can happen is wrong rotation direction.If it turns the wrong way around, either change direction in vesc or swap any two wires. If you use connectors, just mark the cable with colors (blue, red, yellow shrink tube works well).
Thanks a lot.
Now I can try it out.
