Hello again,
How do I connect the Maytech receiver to the ESC? What connector should I use. Sorry but no experience with RCs, ESCs and so on. Thanks in advance!
Hello again,
Plug it into the “COMM” port.
5V → 5V
GND → GND
TXD → RX/SDA
RXD → TX/SCL
Or
5V → 5V
GND → GND
PWM → PPM
Is this correct?
Seems like the closest I can do compared to what your wrote is the following
ESC - RECEIVER:
5v - 5v
GND - GND
TX2/RX2 (maybe both?) - PWM
Nah, you can’t mix TX2/RX2 with PWM/PPM – they’re totally different data protocols. Gotta pick one or the other.
The simplest way is PPM to PWM 'cause it’s got fewer wires than RX/TX.
My bad, the PPM wire is labeled as Servo on your ESC case.
5V → 5V
GND → GND
PWM → Servo
Thanks!
I guess some of my confusion comes from the fact that the white cable in the bundle of “white/black/red” comes out of the ESC at TX2 instead of servo. Maybe it just looks like that because of the white sealant pushing the cable to another position?
