Seems that VeFoil has 2 favourite motors Home Made Flume - #23 by VeFoil - Props & Ducts - FOIL.zone
especially (2017-12-17 a "long " time ago
VeFoil 250Kv, 100A, 3.1Nm Torque (63% more torque than SSS 500kv, 55% more than SSS 360kv)
The following post is worth reading too imho How I will make it true - some points to think about - Propulsion System (Motor, Gears) - FOIL.zone
It sets up the principles found when using a Jet propulsion with a Sup Board. 23 posts in a day then … nothing
@SUP-MIKE data for his jet sup board:
79mm impeller, 394kv, tp5670, 10s, 80a, 25kg is static thrust, 15km/h
impeller pitch is 58mm and gap to nozzle is 0,5mm - pitch ratio = low = 58/79 = 0.73
This being said, the way to go is surely the one opened by @Winging_it and his post:
He improved a spreadshhet called “Hydrofoil Medium AR.xls” …Very informative (imperial units only) metric version in progress since… early March
