Good day everyone!
1st post and to this whole DYI e-foil thing
I’ve read a lot in this forum but can someone explain (demystify) a way to get a rough calculation to estimate e-foil ride times when on foil between various battery / motor size and KV / prop options out there?
There are so many options, tring to sort out which would be the optimal runtime vs weight vs power for an efoil project…
- Which Voltage? 14S10P or 16S10P or 18S10P
- What size motor?
- What motor KV?
- Propeller size and pitch based off the motor size / kv and voltage
Foil size would be based off weight but 1200cm foil for under 175lbs and 1500cm for 175-225lbs.
Any info would be greatly appreciated.
Thank you, Koa
