I have. CNC foam cutter
Hello, I have a CNC foam cutter (it can do wood and aluminum too) I dont use it much, but I am planning on building an efoil. Does anyone have any thoughts on the model, or plans they may want to share? It does not have to be 3D, as I can make the 3D model myself. Also if you live in central florida I can make you one as well. For the first several I make I will charge nothing for the use of the machine as I need to get used to using it.
