For sharing:
I recently had issues like cogging at startup motor with makerbase FSESC 75200_ALU and then with FLIPSKY 75200_ALU PRO 84V.
I use 65161 120 kv motor.
I also had some occasional issue like low voltage
I use 12s8p
The issue disappear when I remove the 150A resettable with lever switch.
For sharing…
So I suppose something inside this resettable « fuse » create problem.
