Hello,
Ive got on issue with my remote or my input settings Im not sure which. Ive run the wizard, tried changing a few settings.
- Current - does nothing
- Current no reverse - a throttle change of 1% causes it to go to 95% duty cycle (even at full throttle motor doesnt reach speeds it should)
- Duty Cycle - motor chatters and spins erstically with no pull of trigger current spikes to 100A, and then oscillates a few amps positive and negative.
Thoughts?
Current build: 5’ x 5" Fiberglass board ~40lbs with electronics, battery, foil.
VESC: Flipsky FSESC 75200 watercooled controller.
Motor: Flipsky 65161 120KV
Controller: VX3 Controller.
Battery: 64V 5600mAh (50c lipo)
