Just another Foil-Assist from south Germany
Started building another Foil-Assist today:
Flipsky waterproof 6384
Flycolor X-cross 160A
6 * Fullsend 4000mAh 6S/1P ( together as 12S/3P)
Battery box: Camdenbox CHDX8-322C
Alubox for electronics: BOXEXPERT Aluminium Industrial Enclosure Alster 150x64x34mm
Motorpod von Kparts
Foildrive 3 Blade Prop
First things first- I needed to drill 4 holes and tap them to be able to mount the Foildriveprop to the Flipsky motor.
Because of the 6 batteries there is not enough space for the electronics in the box - so I put them in an extra box (Sidewinderidea by Oli from @Beenee-foilsports). This aluminium box also serves as a thermal mass to cool the esc.
I added a piece of aluminium to distribute the heat from the ESC faster. ESC will be glued onto with thermal glue.
Mediathek - 2 von 2
Mediathek - 1 von 2
At the moment I´m planing the Batteryconnections. As I´m using 6 Lipos 6S/1P I connect them first into 2 6S/3P with an Adapter and then together to 12S/3P. I´m not shure what I have to do with the Balancecables when the Lipo is in my Foil Assist- Do I have to connect them also in a way?
When I`m charging the packs , I have a ParallelAdapter, where I can plug in the XT60 and the Balancingwires.
Thanks!
You don’t need to connect them. If you want, you can connect a LiPo beeper (just to one) to get an alarm when cell voltage is going below a setable threshold, i.e. 3.4V. Starts to beep when one cell of the connected pack reached 3.4V.
1-8S Lipo Battery Voltage Tester/ Low Voltage Buzzer Alarm/ Battery Voltage Checker with Dual Speakers
https://a.aliexpress.com/_EGayUfq
Today was “solderday…”
Everything is connected. Batterys are full, the Remote is paired and I see a red light.
I pulled the trigger and nothing happend.
I measured the connections- Power is connected to the ESC.
I did not programm the ESC- do I have to?
Thanks…
You can quickly calibrate the remote (which sets max and min throttle) with the instructions (The Calibration Process with PWM Receiver) https://oscarliang.com/how-to-calibrate-esc/
Are you getting this sequence of beeps when powering on the ESC ?
The ESC is not beeping :frowning: Seams to be dead? Is there something I cam measure somewhrer to proof if the esc is dead?
Are you getting the first 3 beeps? Motor needs to be connected when you power on.
Motor is connected, but I get no beeps. I measured the powerconnection- 49,1V .
Can I somehow measure the motor or the esc if it is not damaged?
Thanks!
Looks like you have a Maytech remote, are you getting a connection to that?
Yes, the remote is pairing, I can read the voltage from the battery, I set the Vesc Thr. to none, the Data source to motor cable, The thr. mode to surfboard,
When I push the trigger nothing happens…
Vesc Thr? Your controller x-cross is BLHeli not VESC. You need to configure the esc using BLHeli software.
I had an issue where my ESC where my throttle signal wasn’t detected, I then manually set the throttle max and min and it worked, but I was also playing around so can’t 100% it was that. See settings here. Recommend you try copy a known config like this one for testing. ESC Flycolor X Cross HV3 settings on BlHeli 32 - #52 by kkolli Once you set them within the right ballpark values, then you can do a throttle calibration.
@Mazdautel I think this is a Maytech remote setting, not ESC.
Oh, yes, these where the remote settings. Actually I did not programm the ESC yet with BL Heli32- maybe this is the problem? The ESC is “out of the box”…
I have a Arduino Mini I can take to program the Esc tomorrow. Sorry- I´m not an RC-Guy, I´m a blacksmith :wink:
Thank you!
I connected a arduino Nano with GND and D3 connected to the ESC ( GND and with the BLHelisuit 32 and flashed it sucessfully. I can´t connect to the Flycolor ESC:
As there is no signal from the ESC I´m thinking more and more the ESC is dead.
Sadly I could not fix my Flycolor ESC… luckily I got another ESC- The Kontronik Kosmik 200HV. This ESC is a lot bigger than the flycolor- so I had to fiddle around to get everything in my box…The ESC fills the whole place in the aluminiumbox- good for cooling, I think…
I had to put the remote inside a box (thanks @hanglosse for the file) in the lid
For the board I use the same connectors and rubberbands as @hangloose did.
I tested again if the box is waterproof.
Tomorow will be the first test…
Sorry to hear that, My technical skills have come to end end in trying to help you on this one!
It is foiling…
