@Konstantin_Cunichin:
Checking options for a winding, 11 turns of 1.2mm wire should be easy for manufacturer, that’s close to 30% more copper than original winding. I can in theory fit 15T with some room left for imperfections.
When taking into account the entry and exit wires in slots then i think 13T is the maximum possible with this wire.
Sizing the needed wire for the 8T winding (i’ll wind each tooth separately)
75mm stator plus endcaps: 80mm
8 turns for each coil
50mm start and end margin Estimated coil wire cut length (80x2+8.3xpi)x8+50x2=1590mm
Winding 1mm diameter copper is super hard. I wound a large outrunner with 2 times 1.25mm diameter and it took me days and muscle aiching. I used a large vice mounted to a large table which held the copper wires so i stretched them and used the mass of the iron to literally hammer the threads into the slots.
I would never do it like this again. With higher amount of threads life will become much easier and the fill factor is almost same.
I’ve done 1mm too but i didn’t find it that hard. Thickest i’ve done is 2.5x1.25 square where the wire is like a copper bar. Still found that OK to wind. What i do is to shape the wire with levers and wedges, not by pulling with my hands.
The fill is never the same on multi wire winds as all the unavoidable wire crossings take up space. One 2.5x1.25 equals twentyfive 0.4mm diameter wires… try to keep those untangled for 8 turns
Yes you are right, i used wooden bars additionally to align the threads on the long straight way. But how do form the sling around the corner, the winding head? Seems almost impossible to me. Also the insulation must not be damaged. I used Capton tape to separate the layers at least in the winding head. Might be overkill. Do you have some pictures winding these copper bars?
Super excited to see the results.
Please do some static tests comparing it to 65 flipsky motor(I do not have one so I can’t compare myself).
If It’s not superior to Flipsky then a general redesign is in order(otherwise it kinda defeats the purpose of making it)
