You are right. I totally forgot to set the right material for the rotor
Let me come back in a couple of minutes with something updated.
Ok so here it is
Iâm working with a model I designed that I think very close to the reality :
(This is 45° of the rotor / stator assembly).
So, based on this model here is what I have :
Current situation :
Gives me following data :
These data are in line with whatâs been advertised by @Konstantin_Cunichin (minus copper area / wire fill factor). Iâll therefore consider my motor model valid for following optimizations.
Optimized model considering @Larsb 2mm² rectangular wire :
Larsbâs proposal (8T delta) :
Slimanâs proposal :
=> around 20% more troque at up to 70% of rotor speed compared to Larsâb proposal
Your turn to choose. In the end itâs a compromise between torque and speed
No, itâs not since i will have a battery and controller that i think can saturate the laminations at both kVs. But i agree on the RPM vs lamination thickness. It doesnât make sense to run this motor at 7500RPM
Also your motor model is theory while i have measured real kV of this motor so my figure is correct. Itâs 109kV.
Not sure about this. Konstantin measured the Kv with Vesc tool prior to sending and said they all where 98kV if memory serves. See here :
Yes, might be the case but i trust my generator kV measurement more than VESC controller kV since the kV is a motor parameter, when measured in generator mode you get no effect from ESC.
Your choice, just wanted to help
Yes, sorry, i appreciate it actually. You only get so far alone so a discussion is always valuable
When I saw Franks(@JetboardCologne) post that motor production costs could be near ~50EUR I thinking about it few months already. I even found guys who working with ebikes who familiar with such devices, but no one interested to make it one copy at least without âa bottle of vodkaâ how we saying ![]()
@Larsb ans @Konstantin_Cunichin thanks for your pains
not even started yet. Iâve considered bringing it when we go to my mother in law for christmas, then i can do some winding therapy when needed
Any news on the rewinding?
Any Updates on rewinding?
How is the motor in general, whant to get one of this,
