Now I wonder if i could make some sort of setup where its 1p below mast (25mm) and goes to motor width (50mm) behind mast with the turbine. The turbine opening would be behind mast but in proper water flow. The unit would be longer in the back rather than longer in the front.
Maybe the first test step is even simpler, just bolt this to the back of existing v4 system.
I have to find the best method to connect the impellers to the shaft, the original turbine design has a D shaft and uses a printed spacer to axially lock the impeller. I am not sure the D shaft design will hold to what this will give.
Seems quite sensitive to air intake, i think the next step is to redesign the turbine housing to be placed behind the mast with a single inlet angled towards the bottom instead of dual side inlets.
Tried to get QWEN 3.8 flash next with freecad MCP to design the new version, but failed miserably, so I tried solidcraft, holy slop lord, it is so buggy. They rewrote a cad core in rust, but geoms kernel and import origins are fully bugged.
Just managed to do a quick mock up, giving up this SW for now.
The trust must be like 5kg max at 2500w. The board picks up a little speed, but I had cut-out under full load, and battery was getting hammered.
After a while, the rx stopped responding, I have to check what happened.
My main course of action before scraping this iteration is to build a hydro fairing between motor and turbine stage 1 to avoid losses due to the motor bell cut-outs and possible cavitation due to the shape of motor.
Will add that to cover the motor holes and have a more hydro inlet.
Found a old RX with no more uart but working PPM, and intstalled it in the unit while I wait for new rx delivery.
I will do a RTV silicon potting instead of magic gel next time, to have something more solid and durable.
I have bad 3D scans of both Aerofoils and JetWave impellers. I can post them here if you wish. They are very similar in dimensions, only that JetWave is a 3 blade impeller. Both are 64mm diameter.
As I said scans are not very good, but since you need only hub and one blade it might be possible to construct decent 3D model from them. Audi scans have been auto combined in RevoMetro software, but slot in hub has been misaligned.
