Anyone tried to rig one of these yet with efoil?
It sure would be really nice to integrate phase wire connectors into this and a quick release for cooling…
This is a significant advancement over the Naish Abracadabra plate for our use. Can’t wait to see if somebody uses this with some waterproof quick connects.
Exactly. It is basically the hinged idea that @SoEFoil has been posting for a while. Seems like it is dang near close to what we would need for wiring and plumbing to align and plug together tightly.
Im not sure if that little flange in the front will be able to hold under the forces subjected to the mast, that looks like a one inch section and if its made of aluminium it will eventually start sheering off and you will loose your wing and mast if it fails.
