Liquid Force Thruster Foil Kit
I found this foil and I wanted to know if its a good option for efoiling. Has anyone tried it?
This is a foil for kitefoiling (board weight: 5kg). Its front wing surface is 650cm2.
OK for a efoil use if you are a 50-60kg (120lbs) rider.
For a efoil use (board weight 30kg), a X kg rider, needs a minimum of 10X front wing surface (cm2) up to15X (earlier take-off).
Ex: a 80kg rider (160 lbs) will be fine with 800cm2 (=10x80) front wing, … up to 1200cm2 (=15x80)
A 80kg experienced rider could manage a 650cm2 front wing though at the price of a higher take-off speed. Wing surface and board volume mean comfort for the beginner…
I have Liquid Force Thruster, but I have 60kg and 18kg Board…
Better is Rocket or happy Foil for light drivers…
And for normal drivers RL Wings…
Greetings Frank
