I already tried two different models:
this one is not watertight at all
This one is waterproof. But you need to much force to turn it for pressing the lid against the seal.
Does anybody found a good one?
I have had great luck with these. They come in black or white in a few different sizes. They have a built in seal.
Should be this one, right?
Is 8" enough to put 6S 20Ah Hobbyking Lipo through? What is the height of it?
I’m using those but they are 4 inch, very waterproof and easy to open/close if you grease the o-ring.
i’m just using the hatch to turn the board on and off, and remove the plate where they are mounted.
I’ve noticed Beckson makes a lot of hatches including those on West Marine’s website. Seems like a legit product.
This is also a good hatch (confirmed by cristophe):
https://www.ruedelamer.com/grande-trappe-d-acces-355-x-600-midline-nuovarade.html
My board has a thickness of 10cm. The lipos have a height of 70mm. So it’s almost not possible to use a rectangular hatch because of its height.
Is it watertight? I used osculati and water entered easily in seconds…
I tried 3 different round hatches, all where watertight
Hi bender: could you share the links for those hatches?
I bought them at my local boat shop. I will try to find the brand
Anybody tried a large screw on lid designed for a large bucket yet?
I’ve used this for my jet board. (obviously you need to cut the bottom part down)
Sizes from 110mm up to 315mm
