Very frustrated now.
I rebuilt my pod, after first gearbox failure and motor stuck on the tube.
Then I managed to build a better joint and add also a second bush bearing (ceramic) inside of the pod, so now it’s prop, bearing, oilseal, oilseal, bearing, coupling, thrust bearing, gearbox.
The problem have been a difficult soldering on motor cable (last time I used acid for the enamel, now copper seems oxidized, solder don’t stick too well), the axel is quite long and not perfectly straight or balanced. Cables are bulky (soldering too big).
I assembled everything, silicone on the cables, grease…internal bearing won’t stay in, the cave is too wide… I added 4 small dots of silicone without degreasing the part, then I fit the tube end. Air won’t escape so I played in and out waiting for the pressure to purge. Oilseal behind bearing can’t be accessed.
Seatrial, damn fast and smooth!! Never gone above 2/³ throttle, board won’t stay wet, it lift itself with speed!!! I knew it, 4:1 and less pitch prop is better!! 3 minutes of joy than I slow down and stand up on board, push the gas but the board stall…what the heck! Something slipping…noooo! I had to get back closer to the beach slower and slower and then paddle, something spin free as soon as I accellerate a little.
Back home, totally mad. Try motor pod on a bath tube…nothing, it slip and the prop stops right there. I open the tube, 3 oring hold very firmly… then I see some water dripping from the tube… little amount but salt! The second bearing is out of its seat, useless. The water come in from oilseal because the shaft moves sideway. F…k!
Cut wires, pulled motor out…the cables were almost detached and solderings with melted or bruised shrink tube were ready to short circuit!!!
I’ve a new motor coming now, I will do soldering out of the. The other major problem is that Neugart did not hold the motor shaft, despite tightened very hard.
If possible I will have the bew shaft lathed a tenth thicker… if not, I will reutilize old rotor but should I put Loctite?
At the end of story: gearbox ok, shaft probably to be rebuilt in one single piece, new 236mm pitch 145mm diameter prop ok… still no foiling and summer holidays are next week only… Ask me if I’m happy now
