Mast adapter for Flipsky Motors
Does anyone know if you can buy foil mast adapters/clamps that suit Flipsky waterproof motors. If so could you please provide details, thanks.
There are a lot of mast profiles and motor choices so it depends what components you are trying to join together.
There are some 3d printed models already posted here that you could print yourself or have printed for you.
There are also models that @kian might be able to provide.
Thanks, i realise there many options but thought I’d work backwards from available adapters as i see this as my first and most complex hurdle. Is there as easy way to find these adapters on here as I’m not a regular user and unfamiliar where things are
Well although it’s great to ask questions - it’s also great to try out the search function of the forum😀
This topic is very recent so should even show just below your’s in the “Latest” view
‘ Stl file for a gong v3 65161 motor mount
