Maytech MTSKR1905WF Remote Freezes and unpredictable
I know that Maytech quality is dodgy at best, however I am using a Maytech remote on a new build and int is completely unpredictable. Two symptoms;
  1. I turn the board on - with the hand unit already on and it goes straight to 2000 PWM. I have to shut power to the board and then reset it. I have fixed this by requiring a 2 second less than 1050 read before the main controller accepts input from the Maytech receiver.
  2. While operating for a while, it will just freeze on the current throttle value. This is hard to detect as it looks like a normal PWM signal.
Has anyone else seen these problems?
Try to reset the remote
Does it not get reset every time you turn it on??
I think there is a factory reset option in the menu of the remote. But not 100% sure. You only reboot while turning of, but not reset. If there is no reset option than pair again to the receiver before you have to get away from all power source at least for 1min. Hope that works.
Thank you for your suggestion
