Mini motor for SUP surfing
I’m looking for something that can get up on foil to ride swells that are not breaking- a great spot near me often has good swell that does not beak at higher tide, but still good shape for SUP foiling…if I can just get up on foil.
I can’t flat water start/that requires a huge wing… so I just need something to get up on foil, then I want to glide as usual.
Does this setup allow you to catch swell that is not breaking? Or basically this is just making catching the same waves you normally paddle into, easier?
Hello Jason.
the post i made on the April the 19th with the slightly bigger motor high up the mast definitely did what you are wanting to do no questions. it provides you with a BIG boost if you have a swell to catch and your proficient at pumping the foil up and out of the water you will achieve what you want with ease.
then you can free foil with no drag.
Hey @rcjetman interested in parts list and files, looking for something to put together for a dock start pumping setup to give a little boost. Thanks!
Looks like a good idea! Would it be possible to get your solid works files?
