Well its time to build something new. I have been building my own electric surfboards for 10 + years and really enjoyed the process and the ease of surfing with some extra boost to get me out the back and on the waves.
So now I’m into foiling and im in love ! After learning to ride the foil behind my boat (11,000kg 40 foot power boat ) it gave me the opportunity to learn to ride and also SURF the waves. After achieving free surf NO rope properly for the first time on the weekend its made me re think by e foil approach and spawned this new design.
excuse the excited family member [https://www.youtube.com/watch?v=_a_EmHwBTEI]
So I will now be building 2 sperate E foils to do very different things.
1: will be conventional efoil, submerged prop for long range high power riding. Which I will use on of FR motor / mast on 12 S to get straight into this with less tinkering needed.
2: A surf dedicated setup for Sup paddle foiling with a boost! A small , light weigh wet and Dry motor setup ?
What I intend to do is mount a small 50mm 650 gram out runner with a and a 60 – 65 mm prop as close to the top of the bard as I can and run it on 700 – 900 watts MAX.
Why ??? well I want a board that I can foil in the surf without the drag and disturbed water flow that a lower wet motor system will always induce. The idea is when im paddling out the back to get to the no break zone I want help / boost to do that and reduce the time it takes to get in and out of the wave section. The motor will also help improve my surface speed to me get onto waves earlier as my paddling technique is far from perfect.
Once im up on the foil the motor will become airborne and trun off and most importantly no longer interfere with the water /wave giving me back the pure wave riding feeling I have felt behind my boat.
Further to this my current SUP has a hole in the board that is perfect for running some wires up into a battery / ESC box that can mount to the surface of the board without any permanent modifications to the board needed. So I can try lots of different combos and still remove the system completely at any time + the mast doesn’t need to be modified in any way either as the wires are external.
please excuse the very rough mock up as i came up with this idea 15 mins prior to leaving for the airport and had to do a quick mock-up
.Battery system will be bigger though.
I have just flown out for a 8 day work trip so progress wont start till then but im excited to give this a try as foiling on a wave without drag is something I want try.
what do you guys think ?
