Jordi
January 3, 2025, 4:00pm
1
For sale spare items that I´m not longer using. Including a small description here, please feel free to ask or send me a DM for more info.
FOIL ASSIST (450€) WITH:
-6384 aliexpress
-APD 80A esc
-Camdenboss box
-Maytech remote
-8s2p Molicell battery
-Folding prop and pod for axis mast
Needs a balance charger to get a complete kit (circa 50€)
APD ESC 80AMPS (70 €)
-Advanced power drive esc, minimal size and very reliable. Been using them on the builds and so far have worked as a treat.
3.CAMDENBOSS CHDX8-322C (25 €)
Perfect box for foil assist - Brand new un-opened
8s 15A Daly BMS as per FD batteries (6 €)
FOIL ASSIST gen 2 STYLE UNDER BOARD (make me an offer)
Selling my slim copy of the foil assist to move onto a MAX style for take off in smaller wings.
Based in Spain but happy to ship through Europe
Hi Jordi.
I’m interested by The camdenboss CDX8-322C.
I’m leaving near to The Spain, in south west of France.
How can we proceed?
Cheers, David
Jordi
January 7, 2025, 10:10pm
3
Hi David,
If you provide me with a full address I can check postage cost and go from there.
Jordi
Jordi
February 19, 2025, 10:12am
4
Camdenboss is sold, rest still available.
Jordi
ChrisG
February 20, 2025, 7:28pm
5
Hi @Jordi
I was thinking of buidling a foil assist but I have no qualifications for that.
My goal is mainly to be able to come back to my initial departure point because as a biginner I am drifting a lot.
Could your foil assist work on my AFS carbon mast?
kind regards,
Chris
mterea
March 10, 2025, 10:54am
6
Jordi:
-6384 aliexpress
-APD 80A esc
-Camdenboss box
-Maytech remote
i’m interested in this, whatever you have left. I’m in the UK if possible?
KONUTZ
March 10, 2025, 11:01am
7
@mterea …what are you after???.. im in the Uk and have some bits you might be interested in
6374 130kv Saite motor (unused)
PA12 nylon hub and prop set (2 blade)
DSE hibox - with heat sink added, latch protectors, velcro and cable nickel alloy cable gland (fits 8s3pbattery)
Flipsky remote V2 with receiver.
Nose cone (fits ride engine/slingshot and Fone alloy masts)
Cable guides also in PA12 nylon.
Let me know
K
mterea
March 10, 2025, 11:02am
8
nice will DM thanks 20char
Jordi
March 10, 2025, 2:18pm
9
Hi mterea,
Shipping to th e UK is a bit complicated since brexit…let me know if the rest of the users can not sort you!
Jordi
Jezza
March 10, 2025, 2:49pm
11
Jordi:
Left with:
Gen2 style FD - Slim
Why not just use a different housing to allow a bigger max battery with the slim. Larger battery in front actually means better weight balance with most of the battery between the feet.
Jordi
March 10, 2025, 3:02pm
12
Hi Jezza,
Not sure I understand your question.
I could do a longer battery to get a slim with 10s but the actual ESC is limited to 8 hence the plan on selling and moving to a new build with a thicker casing.
Jordi
Jezza
March 10, 2025, 3:12pm
13
Use a thicker battery even 12S2P. some cells would run inside the slim housing, but most outside in a thciker than slim format. 80A esc is fine. FD only run a 70A vesc.
