Hello fellow builders.
So my 2 build are underway 1 already in the water 1 yet to start BUT a common concern always remains is water getting in where it should not and do i know its happening ?
So i have been thinking about using a small soil moisture relay that i would put inside my battery compartment and other cortical areas that if water was to get in it would trigger an alarm and also potentially a small pump with a pickup at the lowest point in the board and automatically pump the water out ( if a lot gets in ) .
What do you think.
dose anything think such a senor would work ?
of do you know if a different one that is more suitable ?
I plan to do a lot more bigger wave sup e foling and its foolish to think that im not going to get a decent amount of water in at some point and if i have no way of knowing or getting it out on the water then its not fun.
