what voltage is neaded to power the
SSS 56104/500KV Brushless Motor 6 Poles For RC Marine Boats Electric Surfboard
Im going to run my motor at 48v (12s). You can run lower voltages (6s 24v or 8s 32v) but amperage will be higher. The lower the amps, the easier it is on your gear.
