Any suggestions on how to re-secure a motor mount to the Mast would be greatly appreciated. Glue or Screw? Or both?
Thanks Foil fam.
Daniel
Thanks Foil fam.
Daniel
Threaded shafts work good, see here: Daniels (un)geared inflatable (slowly built) - #45 by sat_be - Builds - FOIL.zone
It is very strong, I don’t need to support my long geared pod anymore. Maybe M6 is a bit overkill, depending on the lever through length and weight of the motor M4 or M5 should be fine. Some Motors have threads in the back so you can just put a disc from POM between the mast and the motor to avoid alu on alu.
