I found a picture of a motor mounted pretty much in the middle of the mast and was wondering if its the better way instead of a folding prop.
If the motor is completely out of the water after you push yourself into the wave with motor power, wave riding should be perfect without losing speed cause of the engine drag, right? Or is it to hard to control the height?
