Hello, I want to ask the vases for the appropriate timing for the SSS 56104 - 500kv engine. I have a Hobbywing Seaking 130 A HV and a Lipo 12S battery. Thank you.
Benjo
June 12, 2019, 9:20am
2
There are several threads and posts about it, e.g.
EFOIL.builders
Propulsion System (Motor, Gears)
Hi, Everything is in the title. What is the timing of the 56104 500kv ? Thanks.
Reading time: 3 mins 🕑
Likes: 6 ❤
You should start at 0° and only go higher if necessary, up to 8° may be ok. Everthing higher will produce too much heat.
EFOIL.builders
Electronics (ESC, remote, batteries)
@michion @DavidC I would actually suggest 0-5 degrees, there is really no need for more. 0 will give you maximum torque and more is unnecessary for a 6 pole motor, >8 degrees will produce way too much heat. Absolutely no reason to risk it.
