Motor stuttering - DIY Foil Assist
I’ve built a DIY foil assist powered by two 6s3p batteries (50.4V). The setup includes a Saite 6384 motor, a Flycolor X-Cross 160A ESC, a Matek Systems BEC12S-PRO voltage regulator (9–55V to 5V/8V/12V-5A), and a Maytech MTSKR1905WF V3 remote.
When I first powered it on, everything worked perfectly. I then pushed the throttle to 100% for about 10 seconds. After that, the motor started stuttering. Now it will spin briefly—maybe a single revolution—before stuttering again.
I’ve tried restarting the remote and unplugging/reconnecting the batteries. The motor beeps sound completely normal, exactly as they did when it was working fine.
Any ideas on what could be going wrong and how best to diagnose it? Thanks!
Video on here:
https://www.instagram.com/reel/DNykTpjwL5d/?igsh=MXN0NjZ6OThiNHFxNg==
Long shot… Something similar happened to me when I by accident attached motor to pod with too long screws. Screws touched between motor windings/poles as I remember it…
Try another esc and another motor to locate the problem.
And if you have conductivity meter , you can check the windings , for my motors it is about 40-70mohm.
Btw which kv of saite 6384 did you order?
The stuttering happens now at any throttle?
Ive seen stuttering correlated to loose prop coupling to motor shaft so you might check that
The behaviour you’re describing is typical for motors that require FOC to be driven but are not receiving one…
Online specs say your motor is sensored, it has built in Hall sensors for Field Oriented Control - FOC. I’m not sure if this applies to all models.
Easy way to confirm this is to check if you have 5 thin wires coming out of your motor in addition to 3 thick power wires. If so you cannot control that motor with the driver (ESC) you have, you either have to get a driver that supports FOC control or get a sensor-less motor and use it with the driver (ESC) you already have.
Hope this helps, Cheers!
