has anybody ever looked this?
would this work?
This page looks better for the same product :
Then on Amazon
https://www.amazon.com/Caroute-N300-24V-Brushless-Electric-Saltwater/dp/B00WF521LE
So the cost you use your own 2.4 Ghz receiver and remote would be $879 to USA Address.
Not bad for no monkeying around as long has it has enough RPM to get the speed up.
Seems to have the Wattage. That is for just the Motor and prop and speed control.
Max Speed 7 MPH. I doubt you will find a foil getting you up at 7mph.
So you will need a different prop, and then the fun begins…
9 KPH That was at 3 ton?
