I have a bunch of goodies available for quick sale including three SSS motors, two Neugart gears, a Torqeedo gear (made by Neugart) and two Seaking ESCs.
![IMG_1284|690x403]Hi Sunrise305,
Would you mind shipping worldwide ? I’m located in EU (just asking for now).
Would you also mind letting us know the price tag for each goodies ?
Looks like it costs about $75 to ship up to to 20 lbs (~9 kilos) in a flat rate box of the size listed below. So it would only make sense to do so if you are buying a bunch of the smaller items and more valuable items like the motors, ESCs, gears, etc.
Here are all the prices. They do not include shipping. I am really looking for someone who wants to buy
a lot of stuff or buy the more expensive stuff. Not interested in shipping just a few cheap items.
| Part | Cost | Price |
| Windsurfer | $150 | |
| Foil - JNJ Outdoors | $450 | $293 |
| Neugart PLE 40 5:1 | $356 | $231 |
| Neugart PLE 40 5:1 - USED | $356 | $175 |
| HobbyWing SeaKing V3 130A BL esc | $181 | $118 |
| HobbyWing SeaKing V3 130A BL esc | $181 | $80 |
| Motor - Gearbox Mount machined | $180 | $117 |
| HobbyWing SeaKing V3 130A BL esc | $178 | $116 |
| SSS56104 500kv motor | $150 | $98 |
| SSS56104 500kv motor - USED | $150 | $75 |
| SSS56104 420kv motor | $150 | $98 |
| 4x ZIPPY FLIGHTMAX 5000MAH 5S1P 40C | $118 | $77 |
| 2018 Ride Engine Foil Track Box | $99 | $64 |
| Tenergy TB6-B Balance Charger Discharger 1S-6S Digital Battery Pack Charger | $55 | $36 |
| TotalBoat Liquid Urethane Foam Kit 6 Lb Density, Closed Cell | $53 | $34 |
| Watertight Aluminum Box AN-23P-01 10.24 x 6.30 x 3.56 in. 3.43 lbs. | $52 | $34 |
| FlySky FS-GT3B 2.4GHz 3-Channel Transmitter - USED | $43 | $28 |
| BNTECHGO 8 Gauge Silicone Wire Spool Black 25 Feet Ultra Flexible High Temp 200 deg C 600V 8AWG | $40 | $26 |
| WEST SYSTEM 105A Epoxy Resin (Quart) | $35 | $23 |
| M8 Track Nuts set of four | $32 | $21 |
| AiLi DC Battery Monitor 300V 200A Voltmeter Ammeter Voltage Amp Meter Gauge with Hall Effect Sensor | $31 | $20 |
| ALBRIGHT 24 VOLT SOLENOID - USED | $29 | $19 |
| IWISS Wire Crimping Tool 6-50mm² Cable Lug Crimper Terminal Ratchet Electrician Plier (AWG10-1/10) | $27 | $18 |
| MulWark 9pcs Premium Grade Tempered High Carbon Steel Carpenter File Kit | $26 | $17 |
| Bullet Connectors - 8mm Gold-Plated - 6 Pairs | $25 | $16 |
| RMP 1/4 Inch 6061-T651 aluminum, 12 x 12 inch sheet | $24 | $16 |
| WEST SYSTEM 206A Slow Epoxy Hardener | $24 | $16 |
| 316 Stainless Shoulder Screw, 8 mm Shoulder Diameter, 100 mm Shoulder, M6-1.0 Threads, 11 mm Len | $23 | $15 |
| Seahorse SE-300 Protective Case Without Foam | $23 | $15 |
| Iztor 100 Amp Circuit Breaker Manual Power Fuse Rest | $23 | $15 |
| Amass AS150 Male and Female Anti Spark Connector Plug Set for Battery, ESC, and Charge Lead x2 | $22 | $14 |
| K&S Precision Metals 6520 Steel Plated Tin Sheet, 0.013" Thickness x 12" Width x 18" Length, 29 gauge | $20 | $13 |
| HFS R 2 in 1 Brake Bleeder & Vacuum Pump Test Tuner Tool Kit | $20 | $13 |
| 304 Stainless Screw, 100mm Length, Partially Threaded, M8-1.25 Metric Coarse Threads | $18 | $12 |
| Amass 5 Pair XT90S XT90-S XT90 Connector Anti-Spark Male Female Connector | $18 | $12 |
| FVT 8A Adjustable UBEC | $17 | $11 |
| Upgraded Waterproof Flysky FS-GR3E 2.4G 3CH Receiver DC 5V | $17 | $11 |
| Mini Pump Kit for 301 and 305 in Quart, Gallon, 5 Gallon sizes | $16 | $10 |
| HVAZI 205pcs Metric M2.5 M3 M4 M5 M6 M8 M10 M12 Stainless Steel Nylon Hex Lock Nut Assortment Kit | $16 | $10 |
| Spring-Loaded Rotary Shaft Seal with Wiper Lip, for 5/16" Shaft Diameter, 0.313" ID x 0.750" OD x2 | $15 | $10 |
| Male XT60 Plug to 5.5mm Banana Adapter Converter for RC Turnigy Zippy | $15 | $10 |
| Neiko 50444A O-Ring Assortment, Universal Metrc, 419-Piece Set | $15 | $10 |
| HPS AST-238 6061 T6 Seamless Aluminum Round Tubing, 16 Gauge, 1’ Length, 2-3/8" OD, 0.065" Wall | $15 | $10 |
| Hilitchi 60 Piece Nylon Plastic Waterproof Adjustable 3.5-13mm Cable Glands Joints Cable Gland | $14 | $9 |
| 8 GA AWG Copper Crimp Butt Connectors Battery Wire Cable Install Bay 25 Pieces | $13 | $8 |
| Hilitchi 180pcs M4 Stainless Steel Hex Socket Head Cap Screws Nuts Assortment Kit with Box (M4) | $13 | $8 |
| Hilitchi 210pcs M3 Stainless Steel Hex Socket Head Cap Screws Nuts Assortment Kit with Box (M3) | $13 | $8 |
| Oishi Tech 10 Pairs HXT 4.0mm Redcat Gold Bullet Banana Male Female Plug Connector With Housing | $13 | $8 |
| Derale 13010 Universal Drain Plug Kit with 1/8" NPT Plug | $13 | $8 |
| 88-SUPER-1-1/2X44FT Vinyl Electrical Tape 1 1/2" x 44’ | $12 | $8 |
| Neodymium magnets 20mm x 6mm x 2mm for printer case | $12 | $8 |
| Solas Plastic 7-1/4 X 6P Propeller 0001-073-06-P | $12 | $8 |
| SEACHOICE 11681 Universal Kill Switch Kit | $12 | $8 |
| Vktech 20 Pairs Bullet Banana Plug Connector for RC Battery Gold Plated New (5.5 mm) | $12 | $8 |
| Cytec 12v PC Cpu Water Cooling System Tool Water Pump 63 GPH 4.2W | $12 | $8 |
| M4x40mm 0.7mm Pitch Bolts Socket Cap Head Hex Key Screws 30pcs | $11 | $7 |
| Superior RDCNPF KeepKleen Contour Work Nitrile Gloves | $11 | $7 |
| MERCURY 2-4-C Marine Lubericant W/Teflon 8Oz | $10 | $7 |
| RG178 Coax Coaxial Cable Lead Low Loss RF Adapter Cord 5M Long | $10 | $7 |
| Eowpower 5Pcs Linear Motion Shaft 8mm X 100mm Round Hardened Lathe Bar Rod | $10 | $7 |
| Thrust Needle Roller Bearing 10x24x4 Thrust Bearings | $10 | $7 |
| VXB 608ZR02-ZR02-PTFE Full Ceramic Miniature Bearing 8X22X7 Id=8Mm Od=22Mm Width=7Mm | $10 | $7 |
| EC5 To 5.5mm Bullet Connector Battery Adapter (2pcs/Bag) | $9 | $6 |
| WEST SYSTEM 804-8 Reusable Mixing Sticks 8/Ea | $9 | $6 |
| Floureon 2 Packs RC Lipo Battery Monitor Alarm Checker Low Voltage Buzzer Alarm with LED Indicator | $9 | $6 |
| 117 pcs 3:1 Dual Wall Adhesive Heat Shrink Tubing kit | $9 | $6 |
| Loctite Epoxy Plastic Bonder 0.85-Fluid Ounce Syringe (1363118 ) | $8 | $5 |
| uxcell M6x65mm Stainless Steel Hex Key Socket Head Cap Screws Bolts 10pcs | $8 | $5 |
| M8 x 130mm Threaded Hex Socket Head Cap Screws Bolts Bronze Tone 3 Pcs | $7 | $5 |
| Spreader/Smoother 3.5x6 | $7 | $5 |
| Dap 00688 All-Purpose Adhesive Sealant, 100% Silicone, 2.8-Ounce Tube | $7 | $5 |
| uxcell 8mm to 10mm Type Aluminium Motor DIY Shaft Coupling Joint Connector | $7 | $5 |
| Floureon RC Lipo Battery Monitor Alarm Tester Checker Low Voltage Buzzer with LED for 1-8S Lipo | $6 | $4 |
| Uxcell a15091700ux0090 304 Stainless Steel Dowel Pins Fastener 3mmx40mm Stainless Steel (Pack of 10) | $6 | $4 |
| EC5 Harness For 2 Packs In Parallel 2pcs/Bag | $5 | $3 |
| Protronix Series 7 Silver Thermal Paste High Performance Heatsink Compound for CPU GPU LED | $5 | $3 |
| Vinyl Tubing - 10 feet 5/16 ID - 7/16 OD | $5 | $3 |
| EC5 Female Connectors (5pcs/bag) | $3 | $2 |
| EC5 Male Connectors (5pcs/bag) | $3 | $2 |
I would like to buy the SSS 56104 420kv, the machined motor adapter and the new neugart please. Please PM me with details if you are ok to ship to nz.
Thanks for your detailed post
I was looking for some of your stuffs but shipping cost will be too high for me if I only buy some cheap items. Sorry for that
No worries. Ideal buyer would be in the US.
Where are you located in Florida?
Near Tampa / St Pete
The two PLE40s, the and the foil have been sold. I still have three SSS motors and the Torqeedo drive, along with many of the other items listed above.
