8mm is the outside diameter right?
Can you please detail a little more of how did you manage to pass through the water tube in the interior of the mast?. I can’t understand from your description.
Best Regards,
João Rebelo
Best Regards,
João Rebelo
yes 8mm is the outside diameter
you need to stretch the tube and then it is thin and passes easily
ok Thanks.
If possible to sand a picture from the inside the mast?
Best Regards,
João Rebelo
i filmed a video but could not send it
i’ll try later
that’s how it looks - 19.5 kilometers
with engine unit of Flying_Rodeo
3.5 km extra distance with the same battery
thanks to an effective propeller
19.5 kilometers, an hour and a quarter without a break, crazy
Thank you very much David
Can you please tell me the baterry dimenions ?
And also cal you please tell me your board thickness?
Best Regards,
João Rebelo
Hi
the battery is 25 cm * 26 cm * 7 cm
the thickness of the surfboard is 14.5 cm
Hi There,
Do you have any link or datasheet for your forklift relay? Where did you buy it?
Best Regards,
João Rebelo
On the MOSFETS I see one of the blue wires from the magnet is connected to it (to the black wire) where does the other blue wire from the magnet connect to?
You can use this: https://www.mttec.de/Chargery-Super-HV-S-BEC-10A-3-14S-LiPo
I use the MTTEC Keto in my RC-Heli and happy with it
It connects directly to the battery
This one costs a whole lot less and works great
https://he.aliexpress.com/item/32964723324.html?spm=2114.13010708.0.0.3a994c4dRDZFq3](https://he.aliexpress.com/item/32964723324.html?spm=2114.13010708.0.0.3a994c4dRDZFq3)
Recommend ordering more than one
I ran out of luck after 1500 km on the water,
Water got into the box because of a zip tie that got stuck in the gasket
Sorry to see!
So the relay and BMS didn’t save anything? Was the battery not waterproof on its own?
This battery was not waterproof
Sad to see that… we spend so much time on our projects thinking about them at night… how can we trust them?
